:disguisNOTHING NEW THERE THEN
RIGHT GUYS AND GIRLS I KNOW YOU HAVE HEARD IT ALL BEFORE AND MADE A POEM ABOUT IT BUT CHECK THIS ONE OUT.
PROBABLY ONE OF MANY BUT BOUGHT SSRG 2.4 D TWO WEEKS AGO (IMPORT) DONE 750 MILES SWEET AS ON MOTORWAY @ 90MPH IS THAT OK ITS NOT IN THE RED LINE ? AND WITH BEING FROM THE ISLE OF MAN (ALCATRAZ) ITS A COMFORTABLE PACE RIGHT.....
M6 J 28 LOOK @THE TEMP GAUGE JUST UNDER RED GLIMPSE BACK WITH MISSBELIEF AND WOP IN THE RED BIG TIME ..PULL OVER POP THE HOOD STEAM OUT OF OVERFLOW COOLANT PIPE...CHECK COOLANT PLENTY IN FULL UP IN FACT...NOTICED PRIOR TO PULLIN THE BONNET NO TEMP WARNING LIGHT ON AND STONE COLD HEATER WHILST ON THE HOTTEST SETTING ?????.
TOP RAD HOSE SOLID WITH PRESSURE AS IT WOULD BE IN THIS CASE......LET IT COOL DOWN CHECKED THE WIRES TO STAT ETC FINE
STAR UP AGAIN LET IT IDLE NOT BAD CREEPS UP SLOWLY THOUGH REV IT AND WOLLOP IN THE RED AGAIN.
CHECKED OIL NO SIGN OF WATER INNIT NO SMOKE OUT THE BACK JUST THE USUALL FUMES....CONFUSED BY NOW STUCK IT ON A RECOVERY TRUCK AND BLOKE SAID HEAD GASKET HEATER MATRIX WATERPUMP STAT CRACKED HEAD ETC BY THAT TIME I TOLD HIM TO SHUT UP AND DROP ME AT THE NEAREST PUB LOL
RETURNING TO THE ISLE OF MAN BLOKE FROM GARAGE SAYS HE HAS PRESSURE TESTED THE WATER CHANNELS AND LOST ONLY A SMALL BIT OF PRESSURE AND SAYS HE HAS DRIVIN IT 16 MILES AND THINKS ITS FINE....ADVISE REQUIRED AS I AM CONFUSED....TEMP LIGHT COMES ON VIA PRE IGNITION SO FINE PLENTY OF COOLANT INNIT AND CLEAN OIL HEADGASKET SURELY NOT....WHOS THE GURU OF SURFS IN ERE AS WE CANT GET THE STAFF IN THE ISLE OF MAN ..........FINGERS ARE SORE GOTTA FINISH THERE LOL
ITS GOOD BUT ITS NOT RIGHT????????/e:
