Engine re-build (pictures)
  • Engine re-build (pictures)
    Here are some pics of my engine at various stages of recent re-build, coutesy of Stevo.
    NOTE: Smaller versions now lower in thread.
    Pete
    Nice pics pete General anaesthetic major op stuff.
    Do you have to take it back to steve to have head bolts re-torqued
      Impressive!
      That looks like the work of someone who knows what he is doing. Mightily impressed. I just wish that there was someone down here in Bristol that I could trust to work on my Surf, it would be worth getting the job done properly.
      Do I recall the cost as being around £1700? Considering that some places charge £2000+ to fit a new head this was a bargain.
      I hope it goes as well as it looks!
      Rob G
        them days is over now marky, all stretch bolts on heads now
        [size=5][/size]
          I believe the pictures are a little slow opening, so here's a smaller set.
            and i thought they were more too come
              P1010026.jpg, question
              I'm just in the middle of tearing my engine apart and have a question which hopefully you can help with, in the picture mentioned I can see that you have the oil filter off, behind which is a dirty big (around 36-38mm) nut, built onto the oil filter spigot, do I need to undo this to get the oil filter bracket/cooler off the side of the engine? Mine seems hung up on something and I reckon it's this shaft, answers on a postcard please!!
              Pete
              Life is not a dress rehearsal
              1996 3.0 SSR-G 5-speed
              (Auto's are for the indecisive!!)
                bolt
                Pete
                Yes Pete there is a 12mm bolt behind filter thread.
                Cheers Steve.
                  Cheers for that Pete, well got my engine apart to find.......yup, cracked head on pots 3+4, fortunately, over here a new head is only about NZ$800 and I've found a top chap who'll do the 'swap' for a measly $220 but then add to that around another $1200 worth of parts!! like mains, big ends, re-bore, pistons etc etc not forgetting a hooooge amount for the gasket set!!
                  Still I knew I was taking a punt on this one and after the rebuild my Surf should be good for another 200k+
                  Pics to follow in a few days
                    Pete
                    Hi mate
                    Wish I had the money for that kind of work!
                    I have a quick question for you. Did the guy who rebuilt the engine also time the diesel pump? I only ask as I am having a heck of a job finding anyone that I can trust to do the job properly.
                    If you have a contact number for him then can you PM it to me, that way I can give him a bell and see whether it's worth making the journey. Maybe he can recommend someone nearer Bristol too?
                    Rob G
