Anyone? I need a suggestion or a bigger hammer!
Why is my alternator such a pain to take out!???
i guess thats whats happened... Ill try with some more GENTLEOriginally posted by NiftyNevThey can become a bit wedged in the bracket where the large bottom pivot bolt goes through. In this case it will need a bit of gentle persuasion.
Nev
persuasion later and hope it comes out.
Tim
well it did come out after hitting it harder. stripped it, no idea what i was looking for but gave it a clean and then spent even longer trying to get it all back in (minus the aircon thankfully!). tomorrow Ill plumb it al back in and see if it has helped.
BTW, where should the tiny vac pipe go from the alternator as mine went no-where when I started.
Tim
Originally posted by dirtydogwell it did come out after hitting it harder. stripped it, no idea what i was looking for but gave it a clean and then spent even longer trying to get it all back in (minus the aircon thankfully!). tomorrow Ill plumb it al back in and see if it has helped.
It should be connected to a 'tee' piece directly above the alternator if I remember correctly.
i have removed all the bolts but it will only pivot I cant get it to budge off the mounts...
