I had a long search thru many posts about overheating and cracked heads.
Is there a definate way to know if you have a cracked head without actually dismantling the engine? (i realise im probably dreaming).
I recently had a tune and a comment by the mechanic about my cooling system ( the overflow was low ) has me thinking. Im understand either a pressure test or cooling fluid test would shed some light on the matter but just wanted the advice of some you veterans out there.
