my m8 got a 4runner its a 2.4 efi it will only idle if you turn the nob in side it goes up to 1100 -1200 rpm then turn it of, and when you hit the gas pedel nothing , what could couse this . snake
4 runner non runner
Originally posted by snakemasterye that cable is ok you can see the it moving, the spindel is ok and moves ok
Then it could be the TPS (throttle position sensor)
Have a read here.....
http://toyotasurf.asn.au/forum/search.php?mode=results
Originally posted by snakemasteri got the ecu code up and it is 28 has any body got a scob what 28 could be
28? Are you sure it's not 2 & 8?
1 - Normal
2 - Turbo boost pressure sensor
4 - Coolant temperature sensor
5 - Correction resistance (Pump)
6 - Pump speed sensor (Pump)
7 - Throttle position sensor
8 - Intake air temperature sensor
9 - Vehicle speed sensor
10 - Starter switch
11 - Switch sign (Vehicle not in P or N or A/C on)
12 - Timer control valve (Pump)
13 - Crank position sensor
To clear any codes either disconnect the battery or remove the ECD relay for one minute
ye it came up 2 and then 8 and i must of jumped the gun thinking it was 28 thanks for the info BUSHWHACKER, is there a way to test 2 - Turbo boost pressure sensor ,and 8 - Intake air temperature sensor , or is it a derect replacement, or can i frig them out just to get her running until i get the bits
Originally posted by snakemasterye it came up 2 and then 8 and i must of jumped the gun thinking it was 28 thanks for the info BUSHWHACKER, is there a way to test 2 - Turbo boost pressure sensor ,and 8 - Intake air temperature sensor , or is it a derect replacement, or can i frig them out just to get her running until i get the bits
The boost pressure sensor is in the yellow circle, the airflow sensor in the red circle.
Check that the short rubber pipe in the green circle is secure.
got the codes and all sorted but from ,but no 13 crank position sensor, the prob is i cant find the crank pick up leed , the engine was replased with a 1990 surf 2.4 td which had a throtle on the diesel pump , and i changed it for the fly by wire pump , the thing that conserns me is that there may not be a crank position sensor , where would i find the crank position sensor on the engine ?. if there is not one where can i go from hear . hope you can save the day BUSHWHACKER.
Originally posted by snakemastergot the codes and all sorted but from ,but no 13 crank position sensor, the prob is i cant find the crank pick up leed , the engine was replased with a 1990 surf 2.4 td which had a throtle on the diesel pump , and i changed it for the fly by wire pump , the thing that conserns me is that there may not be a crank position sensor , where would i find the crank position sensor on the engine ?. if there is not one where can i go from hear . hope you can save the day BUSHWHACKER.
