old engine fly by pump , the old mechanal pump was lying out side and got water in it so it is US , at the mo the surf will start but wont take throtle you can push a we stwich on the dash and it will go to 1200 rpm and that is it , i wonder which way to go now buy a M pump , or try to fit a crank pick up . snake
4 runner non runner
well i need some help , could i fit a 2.4 EFI diesel Crank position sensor to make this surf go ( dose the Crank position sensor fit on the bell housing , or on the engine side top or bottom ? ) the surf is a automatic so i have fitted the original tork converter and back plate, and where would i get a Crank position sensor
