I have recently purchased a 92 Surf LN130 from an importer. I have a few questions that I thought someone might be able to answer.
1. When I turn on my headlights (without a key in ignition) my dashboard lights up (thats normal) as well as the fan comes on. Why would the fan come on when the headlights are switched on.
2. I have a Carrozzeria stereo that I believe is stock. None of the rear speakers are working. Is there a simple fix for this? Or do I not have rear speakers?
3. When I turn on the key and allow the glow plugs time to heat up, 5 seconds later I hear a continuous beep sound. Does this mean I can now start the vehicle?
4. When I shift into reverse, I hear a beeping noise. Am I doing something wrong, or do Japanese people need an alarm to remind them they are in reverse?
5. Does anyone know of a parts supplier in Canada for 2.4T?
6. Does anyone have an electronic copy of the owners manual that they could send me?
7. Could you explain what kind of 4WD I have ? I don't mean for that to sound like a stupid question, but without a front differential, will both front wheels turn with full power? And this is why its so bad to drive on dry pavement in 4WD?
Thanks for the help! I need it!
SkydiverBC
SkydiverBC
