Gday all,
I'm fairly new to the surf and yesterday as i tried to take my surf for a spin around the block in 4wd as i was instructed by a mechanic, when i tried to reverse it to disengage 4wd it would not come out and the 4wd light remains on.
This has happened to me before and eventually it went back to normal, however this time im trying not to drive it so i dont cause wind up.
I've been searching your site for about three hours and have got some good ideas but not being very mechanically minded are there any simple steps that i should take before forking out to some mechanic.
Any hints or tips to remedy the problem would be greatly appreciated!
P.s. my ride is a 91 ssr-x manual 2.4, she's a beauty
Thanks so much for any help!!!
, Tonyn is your man for advice where thats concerned. As mentioned a million times in years past. Do not under any circumstances use 4wd unless on loose/ slippy ground. Have a word with that mechanic, tell him to find the centre diff on your truck
