Brake light
  • Brake light
    my E-Brake / Parking Brake light is on.
    (yes i do put the brake in, so its not me)
    i have checked to see if the button is being pressed and it is.
    so where else should i look
    Low fluid or worn pads etc ?
      Its not low fluid.
      i have not looked at my pads yet.
      do they have pad sensors ?
        I think they may, but not sure.
        Hopefully someone who knows will be on soon.
        Trev
          Has the brake pedal gone hard.....that happened when my vacuum pump gave up .
          www.daemon4x4.org
            nope, every thing seem to be fine, and its not hard to stop the hilux.
              My vac pump died in wales .......the first thing i knew about it was going down a very steep hill the brake light came on and no brakes ............
              One of those moments when you find out adrenalin is a brown colour
              www.daemon4x4.org
                Gotta love those moments. had a few in my last vehicle... i did not see the ditch in the middle of the road
                  the pads have audible wear thingys on them, make a $$$$$$ awful noise. check the float in the brake fluid reservior. my missus has just driven off in mine so i cant check to see what sets the light off on the fluid pot.
                  TeaM BOFA4x4 Mac 2008
                  www.bofa4x4.com
                    that how i figured the brake worked, err all the other car i have seen do that.
                    i will look that the fluid thing
                      Trev
                      Nope. just little bits of metal that rub on disc when its worn down to 2-3mm.
