2.4L Diesel Runs Like the Engine is missing
  • 2.4L Diesel Runs Like the Engine is missing
    My 2.4L turbo diesel will, at random, run like it's missing. Already checked the fuel for water, replaced the fuel filter, and adjusted the fuel pressure. Since it happens randomly/ off and on, I'm having a hard time figuring it out. Any suggestions???
    Maybe air getting in to the system somewhere? Had a problem once where the diaphragm on the primer pump was split.
    Roger
      Has someone nicked it then and now you have to push it, mind you 2.4 are a bit underpowered so you could be mistaken for thinking that the engine is missing, try looking under the bonnet for a big metal thing
      If it aint broke dont fix it
        now now now, flippancy and scarcism will get you everywhere
        Bring me the head of a treehugger
