I need to get some pistons and bearings etc. I have an autodata disc that lists the 4runner as the 2-LT engine so am thinking I may be able to order bits for that engine which was available in the UK to use on my 2-LTE. Would this be correct???
Is the 2-LTE the same engine as the 2-LT?
Anything except the crank and conrods, unfortunatly the 2L/T in Surfs has smaller crank bearing journels than the 2L/TE, Don't know how it relates to newer 2L/T's in pickups, but on the Surfs the change over to the 'E' motor in 91/92' was matched by a beefier bottom end to the motor. Newer 2L motors may have the bigger bottom end as well, but i've only played with Surf 2L motors.
Give Stevo a ring, he'll hook you up with everything you'll need.4x4toys.co.uk - Keeping you on and off the road...
