Can anyone tell me how freely their Turbo spins? Mine does not spin freely if I give it a flick with my finger. It stops very quickly although it spins at idle and produces pressure ok????
Turbo Charger.
funny you should say that, i had all my pipes off yesterday and was cleaning the oil out of the turbo with carb cleaner (make sure you last pipe is off when you do this it will completly ruin your engine if it sucks in carb cleaner)
afterwards i spun it by twisting the centre bit, and was surprised to see it spin a good while before slowing to a stop.
if the engine is running, i was able to turn the key off, walk round to the front and then watch it slow down and stop.
when i have been making exhausts for supposed 'sports cars' eg fiat coupe turbos (one in particular 300hp apparently) ive been curious and spun their turbos and pretty much right after you stop turning the shaft the turbo will come to a halt. and turning it is an effort too.Oh Nana, what's my name?
the turbo is oil cooled tho so if you have taken a pipe off and got the engine running then you are bound to get oil spray out at you.Originally posted by gkm24I only ask as when I rev up the engine with the pipe disconnected I get oil sprayed over my arm from the turbo. Obviously the seals are gone but there is no play in the bearings.
Someone correct me if i am wrong please and then you can nominate me then also for iotwhttps://www.facebook.com/groups/henpals/
