why oh why do surfs have such problems bleeding the cooling system? it sdoesnt seem to matter if its a 2.4 or 3.0 either looking at the posts. ive finally got mine running now (thanks bushwacker again )it was very smokey at first but i think that was due to me filling the fuel filter up with half a litre of redex!!is it true after fitting new gasket/head/etc you should run the vehicle with no antifreeze and a coolant flush in it for a few hundred miles to ensure the gasket doesnt become contaminated with ethylene glycol in the coolant? i have done this,have got about 9 litres in so far, but in hot weather will just plain water be ok ?my hoses have stoppped pressurising so much now and i get the odd burp out of it now and again.has anyone looked at a mod in which you could put another 12v water pump into the system somehow?? would this help? i could do the physical part but brains aint me strong point
cooling system
You could fit an air bleed fitting like a few of us have........
http://hiluxsurf.co.uk/forums/showth...ight=air+bleed
Only know of one or two Surf owners installing an Electric Water Pump. Not a good idea in my opinion.
http://www.toyotasurf.asn.au/forum/v...ric+water+pump
This from the old Forum.
http://www.toyotasurf.asn.au/forum/v...t=davies+craig
Originally posted by WARRIOR72is it true after fitting new gasket/head/etc you should run the vehicle with no antifreeze and a coolant flush in it for a few hundred miles to ensure the gasket doesnt become contaminated with ethylene glycol in the coolant? i have done this,have got about 9 litres in so far, but in hot weather will just plain water be ok ?
Originally posted by BUSHWHACKERYou could fit an air bleed fitting like a few of us have........
Originally posted by MattFErrmmm, I still ain't fitted it yet Vince. I spent that long trying to get the cooling system sealed last time I modded it, (poxy soddin' brass tube), that I ain't had the heart to disturb it again. (Yet).
I know what you mean, if it's working OK then leave well alone.
Originally posted by BUSHWHACKERI know what you mean, if it's working OK then leave well alone.
Can i ask, why is it not a good idea to fit an electric water pump? i was thinking of doing just that, in conjunction of course with the standard pump, as long as ya get the flow in the same direction i could'nt see any problems except maybe before the stat opens, i was thinking it would help with flow if fitted to heater side of the system especially if your contemplating doin a second heated veg oil tank or the preheater to one, we used to fit electric pumps to bus systems to help pump to the front of the bus (demisters heaters etc) as the engine pump had a struggle pushing it that far, i got one of the pumps but its 24volt (bugga) also is it not a good idea to run on demineralised water and anti-freeze all the time?Too young to die and too old to give a toss
Originally posted by MattFYeah, I know I'm being a coward, but..... It's sat there waiting to go on, but I'm gonna' wait until I have to do something else on the cooling system before fitting it. (Which knowing me shouldn't be too long). BTW, that just got me thinking, I'll have to update THE thread with the verdict upto just.
Oh no!
you wouldn't, would you? think of the newbies that may stumble upon it, poor souls.
