Right i think i have discovered the route of the fuel leak but wanted to check with you guys.
My truck seemed to be a bit lumpy and slow when cold so followed the advice on here and stuck a bottle of redex in quarter of a tank of fuel (am running on about 80%veg) seemed better starting and running BUT thats when i noticed the fuel leak!!!! could the redex of cleaned some cr@p that was keeping it sealed hence the leak? I am hopeing this is the case as it seems like the cheapest opition.
I have a non EFI engine and through searches on here see its not easy to change the seals on them. But i am gonna give it a go.
What i would like to know is has anyone done it and made a photo walk through???
If not then can i get any extra advice on how to do it? one of the things i REALLY REALLY need to know is, is the seal kit the same for the manual pump as it is for the EFI model? save me getting the wrong one.
Any help or advice would be great as i need to get the truck tip top for the trip to the offroading place kevin (sv1000spilot) found.
Thanks in advance
If not then can i get any extra advice on how to do it? one of the things i REALLY REALLY need to know is, is the seal kit the same for the manual pump as it is for the EFI model? save me getting the wrong one. Any help or advice would be great as i need to get the truck tip top for the trip to the offroading place kevin (sv1000spilot) found.
Thanks in advance
