Having just recieved my eagerly awaited Haynes manual I set about a quick coolant flush and oil change on my 1993 2.4td SSR-G, got all the tools out, laid out a ground sheet, took off the bash plate/ sump guard, confident that I would be able to see the radiator drain plug (just like the picture in the manual) and.... hold on ..... whats this?...... who put another ****** radiator under here? Is this normal or am I just 'lucky'?
I presume I will have to remove the radiator or at least loosen it to get anywhere near the sump plug and radiator drain plug? any clues as to the easiest way to move it?
