hi again!
wondering who could spare some advice?
ive had my truck almost 2 months now, and really like it.
the previous owner explained he had replaced the rear springs. and all is good.
except, when i go over them really narrow speed bumps at work, when the front come over and back down it will hit the bump stops sometimes. and it does bounce a little. so my diag is $$$$ shocks and saggy springs.
so if i were to do the front what would i choose?
i havnt tried going over the bumps with the hard shocks button switched over.
thinking about it, i was under the car the other night on the rear. and i think the previous owner replaced the rear with shocks that arnt electronically adjustable. (i remembered seeing 2 connectors like an mini S-Video type nicely tucked away) no big deal to me, but it is a bit of a shame. the rear end is quite solid, and does not bounce like the front does.
also the rear must be about an inch higher than the front.
i dont want to lift the car, otherwise the front will be higher than the rear, like im carrying building stuff..
but i was told the rear springs are uprated (he probably ment shocks) ive not been in a standard surf, but i imagine the rear now is probably how a standard surf would be if the button was switched over.
i dont have too much money either, but dont see the point of getting cheap rubbish. i like replacing broken things with new that will last and do its job too.
thanks for your help!
