What is the denso unit, that sits above what i think is the power stering pump, and below the thermostat housing on the passenger side of the engine towards the front.
I'm pretty sure it's something to do with the fuel system and it has a pipe that goes on to what i think is the injector leak off pipe across the top of the injectors. Pump??
Should it have any pipes coming out of it not connected to anything? If i remember rightly it was a pipe at the front that went to the injectors, and a pipe towards the rear which comes out the top then bends over and goes down the engine side of it, it was this pipe that doesn't have anything connected. If it's part of the fuel system i'm thinking this may be the cause of my v. poor economy. I'm not asking for miracles but i'd like to be able to get 20-22 mpg out of it.
