Only noticed on saturday(think thats when it started)after a good run that the fan on drivers side at behind grill seems to be running constantly,whereas before it onl came on when car was hot.i found a wire had broken that goes into just under water/coolant cap,a friend who knows diesel engines quite well (tho not surfs)reckons it could be sender unit,is this right?any other reason for this and how do i put it right?will it cause any damage if i keep driving while it is on like this?cheers for any answers<much appreciated!
fan stays on constantly!
The wire you are talking about is the fan switch, if it is broken off then the fan will run continuously.Originally posted by alwoowarOnly noticed on saturday(think thats when it started)after a good run that the fan on drivers side at behind grill seems to be running constantly,whereas before it onl came on when car was hot.i found a wire had broken that goes into just under water/coolant cap,a friend who knows diesel engines quite well (tho not surfs)reckons it could be sender unit,is this right?any other reason for this and how do i put it right?will it cause any damage if i keep driving while it is on like this?cheers for any answers<much appreciated!
Get a new switch, problem solvedIf it aint broke dont fix it
You could take the fuse out which is in the box under the bonnet, but for a short while shouldn't be too much of a problem leaving it runningOriginally posted by alwoowarOnly noticed on saturday(think thats when it started)after a good run that the fan on drivers side at behind grill seems to be running constantly,whereas before it onl came on when car was hot.i found a wire had broken that goes into just under water/coolant cap,a friend who knows diesel engines quite well (tho not surfs)reckons it could be sender unit,is this right?any other reason for this and how do i put it right?will it cause any damage if i keep driving while it is on like this?cheers for any answers<much appreciated!If it aint broke dont fix it
