@ TonyN;Re Fuel pump
  • @ TonyN;Re Fuel pump
    Hi Tony, this ones still going I'm afraid, I'll attempt to put pics of Sledges pump for you to look at if it helps, will it fit on My LN130??
    PS: Does the cam belt HAVE to come off to get the fuel pump off? and if the pump comes off for new seals, will it need to go to a specialist to be re-calibrated etc??
    Rob
    Still working for the man!
    nice pics looks like my house lol
        any luck yet plumb bob
          you can do the O ring and the top seal witout removing the pump at all on the pump pictured above...just remove the airbox...undo the 4 allen headed screws (think they are 5mm!) on the top and the 34?mm sensor lock nut..then just lift the top change the main seal (milners..about £7 for a set) then swap the O ring on the sensor plug...
          it takes about 30mins..as opposed to HOURS if you remove the pump! :-)
          HTH
          S
          sparkz
          http://www.elite4x4.co.uk/
            No answer from tony yet, and I've e-mailed him too.
            Rob
              HTH
              S
              My pump is different to that one, and its not leaking from the top seal, its leaking from the back of the pump adjacent to the fuel cut off solenoid.
              Rob
                Hi mate, sorry but it won't fit, you need a pump of a Non-EFI truck, the pics you posted are for a EFI truck.
                Up to 90-91'ish are non-EFI. 91 on are EFI.
                Sorry for the delay.
                  No worries, at least I know, don't suppose you happen to have one lurkin'?
                  Also does the cam belt HAVE to come off to remove the pump?
                  Rob
                    http://com1.runboard.com/b4x4toys.f1.t67
                      Cheers, I missed that one.
                      Rob
                        Well, I've spoken to several fuel injection specialists localish to me, and the general consensus is that they will have to take the pump out to find the leak coz it doesn't appear to be on the top.
                        Cost to remove pump, renew seals, bench test and calibrate will be in the region of £750.00. so thats a no brainer, ain't gonna get done.
                        I can't afford to spend another grand on a vehicle that already owes me 3k and is only worth about £1750.00 on a good day.
                        Rob
                          why not try and take it out yourself, i got the efi one out quite easy
                            Have to take the cam belt off, and half the left hand side of the engine to get it out, so it's not for the faint hearted, and if I take it out myself there is the possibility that it may never run again.
                            Rob
                              if you were closer i'd help ya
