hi guys wonder if anyone has had this problem and what the cause/solution is.
i started my surf up five minutes before i left work tonight as per usual, its only about a 4 mile drive home and everything was fine till i pulled into my street and heard a gurgling sound coming from the passenger footwell area.
after reversing into my parking space i saw a trail of what i thought to be atf fluid,but on closer inspection its coolant.the temperature gauge reads fine (bang on centre as usual) ive lost warm air from heater..prob due to low coolant, but the coolant appears to be blowing out the pipe coming out of the expansion tank near the nearside of the radiator. it appears to burp and gurgle then chuck out frothy red coolant every ten or so seconds.the coolant cap appears fine and fairly cold to the touch with no leaks. could this be a sticking thermostat or something worse??! thing is i just spent £400 on tyres and new glow plugs and it was running beautifull!!
any help much appreciated, head and timing belt was done 18 months ago, but not sure if it was the modded head (id just bought it with the receipts) cheers guys
