I have done the 'pumping the primer' trick and it was fine for a day and then yesterday it started oplaying up again (low idle at lights and the engine cutting out....). When this happens I get quite a lot of black smoke that turns white and then gradually disappears altogether from exhaust as I increase revs by putting my foot on accelerator pedal to drive away. Either that or the engine cuts out before I get chance to put my foot on the pedal.
What could this be? WOuld air in the fuel pump cause this smoke?
Why does the smoke get lighter if I increase the revs again?
