Bit of help and advice again please guys.The oil leak from the head is getting progressively worse so Im going to tackle the head gasket at the weekend. I also want renew the valve stem oil seals while the heads off ( and possibly re-seat the valves if theyre a bit pitted) but Ive looked on both milners and roughtrax sites and cant find the valve seals listed as available parts. I presume that theyre included in a full head set, but I was hoping to leave the inlet and exhaust manifold on the head so I dont really want to be buying gaskets that I dont need. Ive read some previous threads about taking the head off so I think Im right that it can be done with the ancilliaries still attached, but can I get the valve seals seperately from somewhere?
Complete Gasket Set?
..... and an armfull of shims if you are going to grind in the valves!Originally posted by Billy-No-MoneyBit of help and advice again please guys.The oil leak from the head is getting progressively worse so Im going to tackle the head gasket at the weekend. I also want renew the valve stem oil seals while the heads off ( and possibly re-seat the valves if theyre a bit pitted) but Ive looked on both milners and roughtrax sites and cant find the valve seals listed as available parts. I presume that theyre included in a full head set, but I was hoping to leave the inlet and exhaust manifold on the head so I dont really want to be buying gaskets that I dont need. Ive read some previous threads about taking the head off so I think Im right that it can be done with the ancilliaries still attached, but can I get the valve seals seperately from somewhere?Bring me the head of a treehugger
