Hi all. I've just fitted a new head. Trying to set the timing now - Cam lines up okay but then try and line up crank and it locks - just can't turn it.
if you've tightened the head (stretch bolts) and the timing is really out, maybe you can remove the cam to stop the valves hitting the pistons (assuming thats whats wrong - not sure!) then set the marks as per the pics.
leave the glow plugs out so there's no compression (although that shouldn't be the problem)
You were right Boyo - moved the cam, positioned crank and then tightened cam. Everything is turning okay now. Only slight problem is the cup around oneof the valves (the one right at the back of course!) is sticking. As the valve opens there is a loud pop where this cup is sticking. Not sure why, but it looks like the cam will have to come out again to sort it out. Thanks Boyo. Vic
I've never had the head off but would assume if timing marks for Crank and Cam are not in the correct position while the head is bolted down there would be a risk of damage such as a valve touching a piston and being bent in the process.
Nev
Hi Nev,
Agreed - I was pondering this last night - if a valve has been bent coz the timing was out then its off with the head (again, ouch and new bolts).
Would have needed a lot of pressure to bend one though.
