2.4 Lt...2.4 Lte ?
  • 2.4 Lt...2.4 Lte ?
    Ok just a quick question... Does anyone know if a 2.4lt ever had overhead cam or was it just rockers? The reason i ask is i may have found a block and pistons for my 2.4lte but the guy only knows that the engine block is from a 92 and the head that was on it was overhead cam like my lte any idea ? Thanks in advance
    The heads on the 2lt and the 2lte engines are the same I believe.
    If the donor truck was a 92 then the engine should be a 2lte.
    If its not an efi engine then it wont fit in an efi truck because it wont have the crank sensor in the block.
    Hope this makes some sense
    I'm a custard donut monster
      Am i correct in thinking , that looking from the front the crank sensor is on the r/h side of engine in the middle of engine approx 2" up from the bottom of block ?
        If your truck (1st gen) is the same as Sumo's , you have the EARLY type engine with rocker valve engine and head . Not the same as 2lt or 2 lte .
