Ok just a quick question... Does anyone know if a 2.4lt ever had overhead cam or was it just rockers? The reason i ask is i may have found a block and pistons for my 2.4lte but the guy only knows that the engine block is from a 92 and the head that was on it was overhead cam like my lte any idea ? Thanks in advance
2.4 Lt...2.4 Lte ?
Originally posted by fenman666Ok just a quick question... Does anyone know if a 2.4lt ever had overhead cam or was it just rockers? The reason i ask is i may have found a block and pistons for my 2.4lte but the guy only knows that the engine block is from a 92 and the head that was on it was overhead cam like my lte any idea ? Thanks in advance
The heads on the 2lt and the 2lte engines are the same I believe.
If the donor truck was a 92 then the engine should be a 2lte.
If its not an efi engine then it wont fit in an efi truck because it wont have the crank sensor in the block.
Hope this makes some senseI'm a custard donut monster
