on my 2.4 auto, the 4WD selector works a treat, as does the hi-lo box. the problem is that I cant switch from hi to lo or vice versa with the engine running cos the gears grate when i do. never tried it in the move, only when parked up. Should I have to switch the engine of to change ratios, or is something broken?
grating gears
Originally posted by Billy-No-Moneyon my 2.4 auto, the 4WD selector works a treat, as does the hi-lo box. the problem is that I cant switch from hi to lo or vice versa with the engine running cos the gears grate when i do. never tried it in the move, only when parked up. Should I have to switch the engine of to change ratios, or is something broken?
You need to select neutral or park first.
