or am i just paranoid? seems that i got the same syptoms as everyone else, and that every piece of advice, from adjusting the pump output to fitting a new head, would solve my probs. I think my head is going to explode.
paranoia
 Just as a little side note, stop reading all the archives and worrying. You'll do yourself no favours. It's a natural first phase of Surf ownership, so speed through it. You will undoubtedly have some problems that need sorting, but they will generally be fairly minor, easily sorted, problems. If you have any worries about a particular thing, pinpoint the source of the problem and ask advice, but don't worry that you *may* have major problems. If anything stops working completely, that's the only time you need to start worrying. You will undoubtedly have some problems that need sorting, but they will generally be fairly minor, easily sorted, problems. If you have any worries about a particular thing, pinpoint the source of the problem and ask advice, but don't worry that you *may* have major problems. If anything stops working completely, that's the only time you need to start worrying. The Surf isn't half as quirky as the archives will make you believe. You have to remember that the archives are built from people *when* they have faults and problems. They aren't built from people posting on a weekly basis to say that things are working perfectly. The Surf isn't half as quirky as the archives will make you believe. You have to remember that the archives are built from people *when* they have faults and problems. They aren't built from people posting on a weekly basis to say that things are working perfectly.
