well decided to change the glowplugs on the truck, no problems except for me having memory loss on the order of the bits that go on the stud for the electrics to the bus bar, i think it goes like this from bottom of stud up: insulator, busbar, electrical connector, nylon/ rubber bush then the holding nut, hope this makes sense its easy when you see it but trying to explain it isnt so easy
does this sound right?
cheers
cheers
