Auto box problems :-( Help Help Help
  • Auto box problems :-( Help Help Help
    Can anyone help...I'm having probs with my auto box on a 2.4td surf......everything was fine this morning on the way to work...Then on the way home i stopped of at the shops....then when i came to start of again, found that surf wouldnt move of in any gear....I noticed the warning light AT/P on the dash was on when park was selected. As i dont own a handbook, can anyone tell me if they might a clue what the prob is or what the light warning is for....
    Also as i may need a auto box, does anyone have one for sale..or know where i could get on.....
    Any help would be appreciated..
    Col
    as far as I know the warning light you mention comes on when the hi / lo range lever is in neutral, this would also explain your problem, could you have accidently nudged it into neutral when getting in / out , worth checking
    Former owner of 94 Surf SSR-X 3.0 TD
      Thanks for the reply rob....yes i agree this could have happend....Where should the lever be positioned under normal driving....
        In the H position, back away from the dash
        =SOLD UP!=
          the lever should be pulled right back H2
            thanks guys.........Ill check the position of the lever tommorow....as the AA towed it to a garage...
            I'm goin to look a right ciint if its just the lever that i've knocked....hey could be worse though cud hav been lookin at a new box..
            Chears again Col.........ill let you know what happens..
              just make sure the gear selector is in park or N to get the H/L2 into position
                10 posts and looks like hes a candidate for the cellar
                Bogus
                Сви можемо
                  Bogus
                  tthat has to be the quickest yet to be cellar fodder
                    We should also put the AA man in the cellar....... I mean check the transfer box is in neutral, it is not rocket science for the "very nice man" or "the man who can" is it....... is it?
                    Bring me the head of a treehugger
