Loss of power steering
  • Loss of power steering
    My son's Surf has lost power steering..............he said sceeching noise ,which then stopped and then steering heavy.I have had a look and the power steering pump belt is totally loose.Have looked at our Aussie manual which says tighten up by adjusting idler pulley but our design seems to be a slotted curved bar no idler pulley.Can only see one bolt attaching pump to engine.
    I suppose it is a case of trying to adjust and see what happens???
    Perhaps we should change belt ?
    Hopefully pump will be OK as pump pulley runs freely but not so freely that I feel shaft is broken.(remains to be seen I guess)
    Any comments from anyone would be appreciated as usual.
    Derek
    If you look front the front of the engine, there are bolts at 1 o'clock (pivot bolt) and 4 o'clock (adjuster bolt in slot) and the slot bar has a bolt the other end at about 7 o'clock. ( you may need to loosen this so the adjuster will pivot as you move the pump )
    If you remove the passenger side battery, its easier to get to everything.
    I'd get new belt for it while your down there fiddling around.
      Thanks Tony....you have confirmed my thoughts.Here's hoping the pump isn't knackered !!!!!!!!!!!!!
        2.4 power steering bolts sometimes break so check this as well.
