timing belt alignment marks
  • timing belt alignment marks
    I'm replacing my timing belt and was wondering if anyone had the specs for putting in a new one?
    Thanks again,
    Canadian Surfer
    I'm assuming here that the td is the same as the standard diesel, The pullys are quite clearly marked and its fairly straight forward theres plenty of room to get in there, the only prob i had was re fitting the timming cover mine was twisted out of shape. would recomend changing the tensioner and idler pully at the same time its a few quid more but is worth it.
      yeah, its no biggy, just line up the marks, keep the belt tight between the pullys and the slack bit by the tensioner, turn it over by hand and check they realign after 1 or 2 turns and it done.
      The cam pully mark is at 6 o'clock, not 12, thats about the only bit that could catch you out.
        easily done...
        it's in me shed, mate.
          hey guys, can any of you post up what the parts numbers were for the belts and pulleys if you have them? its hard to get them here in canada, and there's alot of mishaps with cross referencing part #s
          thanx, i really appreciate it.
          edit** i think this is the right one, here on ebay, yay/nay?
          http://cgi.ebay.com/GENUINE-TOYOTA-H...QQcmdZViewItem
            For all you Canadians who are getting into the joy of Surfs seeing as your govenrnment is allowing them into the country -
            http://www.toyotasurf.asn.au/techsite/timingbelt.htm
            ALSO - http://www.toyotasurf.asn.au
            the tech section has loads of write ups.
            I followed the timing belt write up and it was a good un.
            Take the radiator out - it will make life a lot easier.
            Another member of the 'A' team
              Super big thanx for those links. That helps alot,
              did you get a chance to check out that link, is that the right belt?,
              thanx,
              -Chris
                Originally posted by Chillitt
                easily done...
                Very!!!!!
                "Canis Auxilio Servimus"
