Sump bolt/plug
  • Sump bolt/plug
    Just a quickie. Are copper washers okay to use on the sump bolt, rather than the specific crush washers? If so, what's the o/d of the sump bolt?
    Cheers.
    Cheers.
    I used a fibre washer on mine, you can buy a pack of various sizes from the likes of halfords.
      Back on form I see, Vince. I just have a preference for copper over fibre. Moulds to the contours more easily. I assume if you've used fibre, 2mm thick copper should be fine, then? Was just going to order some, but have no idea what size the bolt is. And for less than a fiver for a pack, I'll have a lifetimes supply, even at my oil change interval zealot level.
        With the copper you can use time and time again, where the fibre washers you supposed to replace
        Gaz
          Annealing is a wonderful thing, ain't it. Have a bag of 50 on their way, so should be set for life.
