Can anyone please tell me what the correct rpm should be on startup (cold) before pressing idle up switch ...?
Rpm cold?
i think mine is about 750Originally posted by fenman666Can anyone please tell me what the correct rpm should be on startup (cold) before pressing idle up switch ...?Last edited by stormforce; 10 January 2007, 21:34.https://www.facebook.com/groups/henpals/
Not that it gets very cold here but mine is the same. I can hear the engine sound change after a few minutes as it warms up and the ECU compensates for this. Normal idle (manual) is 750RPM and a little higher the first few minutes depending on ambient temp.Idle up is 1200-1250.Originally posted by MaverickOn cold mornings mine always starts on a slightly higher rpm than normal. I presumed the computer was adjusting for something.
Nev
Originally posted by NiftyNevNot that it gets very cold here but mine is the same. I can hear the engine sound change after a few minutes as it warms up and the ECU compensates for this. Normal idle (manual) is 750RPM and a little higher the first few minutes depending on ambient temp.Idle up is 1200-1250.
Nev
Mine too!
