Hi want to do a full service on my 2.4td kn130 but not sure on how to do the gearbox oil, have read lots of posts and most say buy loads of oil and take oil pipes off put one in a empty buket and the other one in another bucket full of new oil and run untill clean oil comes through. Any body got some photos of where these pipes are. and where is the filter (do you clean it or replace it). One more thing is this oil any good http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=290054990975 and is there enough.
Gearbox oil change
Unless you have a specific problem, just drain it and refill is good enough, do it a couple of times in the space of a month and you'll have got most of the old oil out, and saved lots of hassle and oil.
Then change it annually, which is still more way more often than the specs say, and you'll be golden.
