My heater started blowing cold air a day ago and next thing you know my engine started over heating, when I popped the hood, coolant was boiling and overflowing the resevoir. I figured it was maybe a thermostat, I removed it and tested it and I still have the same problem. I also tested my antifreeze for oil, as I was told I may have a cracked cylinder head... nothing. Next guess would be water pump? How do I know if this is the problem? Any other guess's as to whats going on?
Thanks again
canadian surfer
Thanks again
canadian surfer
