okay so its not a surf but its pretty much the same(2.4td landcruiser)
been out and about in it all day then went to work tonight turned it of for about fifteen mins then started it up it was blowing cold air and the temp went right up to almost boiling then the heating started blowing hot and the temp went right down to normal it did this twice the first time I put 1/2 pint of water in the second time had come home and it took about 2 1/2 pints?
so let it cool down went out took rad cap of and it through all the extra water I had put out in a fountain of cold water?
the other thing is if you turn the heater from hot to cold and then back again
it stays cold until its almost boiling and then starts working and the temp drop very fast?
any ideas no oil in the water and no water in the oil?????????
