Is there a heat sensor?
  • Is there a heat sensor?
    I have noticed that my Surf (2.4TD Auto) runs a hell of a lot better once the engine has thoroughly warmed up. It takes a good 15-20 minutes of driving before it will pull at the top end.
    Is there any sort of fuel temperature sensor, or something else that would cause this? There is a very noticeable difference. I have a replacement fuel filter, should I fit it??
    Rob G
    its worth a go mate also put the diesel redex through it 1 bottle to 1/4 tank of diesel
      I did try Redex
      I did the Redex thing but used half a bottle to a tank of fuel, I guess you are saying that the recommended dose isn't strong enough to remove the claggy residues in the injection system, so I will give it another go.
      Cheers m8
      Rob G
        Rob G
        See Technical-Elecrtical-Interior light. We had quite a discussion on this subject.
        Tich
