Overheating still ????
  • Overheating still ????
    Canadian. Have the 91 2.4, cracked the head. put on new head from allhead in au, 2 10 inch electric fans, new radiator, and radiator additive to give extra degrees, and it still overheats going up a hill ? any ideas ?
    Did you re-new the radiator cap and the thermostat?
    You could have an air-lock in the cooling system.
      does it over heat if you lock it down into a lower gear? if not, then you need to change your transmission fluid. and maybe fit a transmission cooler if you are towing
      it's in me shed, mate.
        cap ok tranny maybe
        ya cap and thermostats good, at oil light did come on once on a tough go, will change fluid and filter and get tranny cooler and see what happens, need brakes to but that' another story, thanks for the tips
