Checked the wiper motor assembly and the screen washer, and it doesn't
appear to be leaking in there. Roof wadding dry. and Surf angled down to
the front slightly, so it doesn't appear to be the sunroof either. Has anyone
had it leaking in around that plastic/metal? trim that goes around the top of
the window in front of the window rubber? If so, is it easy to remove and
seal? Have popped some insulation tape over it to see if that stops the leak,
just to double check.
Cheers.
Cheers.
