hi all im appealing to the technical minded ones out there,my mate has a 91 2.4 efi... hes gradually lost power over the last few days and now it wont go above 20mph.we think its the bottom end going,as when you rev it anything above 2000 rpm it sounds like a bag of spanners rattling in the sump area.does anyone know approx how long/difficulty in removing the sump,whip the crank out and the pistons out?ive looked in my autodata but it only lists a 4 runner,or a 24 td hilux pick up at 4.5 hrs to do.i imagine the pick up would be easier due to axle height? im begining to think that a decent 2nd hand engine may be quicker and cheaper in the long run. any input/advice/prices or engines apreciated cheers
2.4 lte efi engine problem
Is there any oil pressure? if the big ends have gone the oil pressure should be through the floor! normally the oil pressure should be over the 1st marker on the gauge, with big ends blown it normally struggles to leave the lower end of the scale.Originally posted by WARRIOR72hi all im appealing to the technical minded ones out there,my mate has a 91 2.4 efi... hes gradually lost power over the last few days and now it wont go above 20mph.we think its the bottom end going,as when you rev it anything above 2000 rpm it sounds like a bag of spanners rattling in the sump area.does anyone know approx how long/difficulty in removing the sump,whip the crank out and the pistons out?ive looked in my autodata but it only lists a 4 runner,or a 24 td hilux pick up at 4.5 hrs to do.i imagine the pick up would be easier due to axle height? im begining to think that a decent 2nd hand engine may be quicker and cheaper in the long run. any input/advice/prices or engines apreciated cheers
Also if you look at the 4 runner 2.4tdi on autodata the times are similarBring me the head of a treehugger
ill pop over tomo and have a look at it cheers (but i feel very guilty turning up there with my surf running fine and his sitting there sounding very sorry for itself) must admit i didnt check oil pressure
but if the timing skipped a tooth would it still run ok up to 2000 rpm ? when it does go over theres no smoke or 'missing' as such just loads of noise ?!DONT RUN WIV BIG DOGS IF U CANT PI** UP TALL TREES
Originally posted by WARRIOR72ill pop over tomo and have a look at it cheers (but i feel very guilty turning up there with my surf running fine and his sitting there sounding very sorry for itself) must admit i didnt check oil pressure
It'll run, but it'll sound/feel really rough.
