Higher output dynamo's
  • Higher output dynamo's
    Howdy folks;
    in the process of rebuilding the 2LT - the dynamo ( alternator ) is 55 amp
    seems paltry - would like to incease this to at least 80 amp - winch , aux lamps etc..
    has anyone addressed this issue before- and what have you done about this
    would you care to share
    already discussed the idea of new Stator - Rectifer is the bigger issue?
    cheers thanks for your imput
    Not sure if it's the MR2 alternator that's a higher rated close fit. Other
    option would be to have a word with your local auto electrical specialist.
      Howdy MattF
      Cheers thanks for the idea- yet the MR2 is petrol yes?
      will not have the vacuum pump on the backside - i have heard of the aux electric vacuum pump idea- rather stay as close to original as possible
      cheers ya
        Only other option is to brainpick your local auto sparks then.
          howdy MattF
          cheers thanks
          a good challenge I see before me
          thanks ya
            I took my altrenator to be rebuilt, and they replaced the internals with higher output alternatives... never got a straight answer where they came from, but replacing the stator with one that fills the original case better, will get you ther result you are looking for.
            So carfully strip it down, photos of how it came apart, and a trip to you local parts store with the oringinal stator and the case... and see what else fits...
              Howdy AndyLala:
              Cheers thanks:
              I will bug my local electrical guy again and see. But I did speak at great length with an expert -
              here is the states there is a company that offers a mobile welder running off your trucks dynamo - so I spoke to the guy who supplies all the guts for the 90 amp dynamo requirements
              Stator is not the problem , is heavy duty rectifier that can handle the increase .
              May have to turn my search there and see if I can get some guts
              care to pass on the name of the shoppe
              say ? what year is your rig ? is LN130 no?
              Cheers thanks ya
                As it is in the profile to the left...
                '91 LN130W with a 2L-TE, its a late '91 born in November...
                And it has the vacuum pump in front of the alternator.
                The guys who rebuilt the alternator are Sahib Electronics in Hanger Lane, West London... in the UK...
                www.yell.co.uk should be able to give you the contact details...
                  Originally posted by nomadix
                  Howdy folks;
                  you say desert southwest in your location, is that UK 'cos there is an excelent starter/alternator re builder on the devon cornwall border - he rebuilt my volvo starter while I waited, on a sunday, interupting his gardening, new solonoid clutch, bearings etc for £25 a true gent!!
                  Tony
                    howdy fatfires:
                    Stateside these days - Desert southwest - Sonoran Desert to be exact
                    If you can get me his name or contact info I can reach him and perhaps get some ideas on options
                    AndyLala: should have looked round a bit - and wanted to make sure
                    I suppose the questions I should be asking is would this LN130 dynamo work on my LN67 - 2L-T ( 1st generation ? ) as to your 2L-TE
                    cheers ya thanks
                      1st gen alternator is different wirring to a 2nd gen . Sumo made a 2nd gen one fit and I did supply him one from a pick up 2.4 which was the same as 1st gen wirring.
                      So as far as I know you can fit a 2nd gen to a 1st gen by moddyfiying (spell check) the wirring loom .
                        Howdy Vagrant no.2:
                        Cheers thanks ya
                        I may have seen a write up somewhere's about the loom or simply the plug
                        how much ( many ) amps are these 2nd generation pushing
                        Now the next question is how plentiful are these dynamo's?
                        A good thing here stateside is CarParts.com - you can hunt parts from many sources in one site and see inventory - only vehicles available in North Amerika
                        Dont believe secnd gen 2 L-TE'S every came here
                        cheers thanks again
                          70
                          Nev
                            howdy NiftyNev:
                            cheers thanks:
                            not bad - the Hitachi from an Isuzu box truck - nearest swap I have come across , is 80 amp
                            Guess i am setting my sights on a 2nd gen 2LT-E dynamo
                            now just have to save my shrapnel for postage
                            cheers thanks ya
                              Just following up from this, I've created a post in the mods section with a higher output alternator I've found...
                              https://hiluxsurf.co.uk/forum/modifi...tor-for-1kzt-e
                              Thanks
                              Rob Watson (forum owner and admin)
