can someone please help me. today my surf has started to smoke on tick-over there is no water coming out and it seems ok when driving, have just disconected my egr valve and it is no different also the water is pouring out of my header tank but it wasn't over heating
white/blue smoke
 Doesn't sound good with your location i would surgest that you contact TonyN...4x4Toyshttp://www.4x4toys.co.uk/Originally posted by j.hellcan someone please help me. today my surf has started to smoke on tick-over there is no water coming out and it seems ok when driving, have just disconected my egr valve and it is no different also the water is pouring out of my header tank but it wasn't over heatingwww.daemon4x4.org
 He been here, we played with his brakes.Originally posted by WoodzieDoesn't sound good with your location i would surgest that you contact TonyN...4x4Toyshttp://www.4x4toys.co.uk/
 I checked his coolant (as normal for every 2.4 I see! ), was OK at the time, Outlook doesn't look so good now...........4x4toys.co.uk - Keeping you on and off the road...
 Get a rad cap and 'stat. Running without a 'stat will cause rather than cureOriginally posted by j.hellhas the thermostat gone then or is it something else if the stat has gone can i take it out till i can get a new one
 problems. Just pop a new rad cap on and replace the thermostat when you
 get it.
 Go to a motor factors. There are a couple of general types of cap forOriginally posted by j.hellany ideas where i can get a rad cap and stat on a sunday need the car for work on monday
 Toyota's. Make sure you get the one with the correct depth bottom
 section, with a pressure rating of 0.9 bar or 13 psi/lb. Wouldn't worry
 too much about getting the 'stat tomorrow, as it sounds more cap
 related than 'stat related. Just order a 'stat from Toyota on Monday.
 Very rare that one of your local factors won't be open on a Sunday. If
 not, there's always Halfrauds. Motosave may open Sunday as well.
 http://www.motosave.co.uk/
