pulled the injector pump off ferrets truck today(deep joy.. not cold at all..
) here is a picture of the underside, should there be a bolt in the threaded hole? is this why it leaks? or are we clutching at straws? also if its not that, the is an oval plate on the back of the pump, if we pull that to replace the seal, will any expensive springy bits leap out, never to be seen again? ta.
