Opinions please.
Anybody ever had a rad cap top seal cause problems,
allowing some minor coolant loss through the cap itself, even though the
seal appears intact? Still got a minor leak from somewhere. No discolouration
on the brass senders, so ruling those out. Sealed top hose with hermatite red
at both ends the other week, and the brass section in the top hose is 38mm,
so the hose is a snug fit on that. Also nipped up all the jubilee's. Still slight
dampness on thermostat housing, and splatter on that side of the engine,
however. So, what are the chances of it being knacked rad cap under certain
conditions?
Anybody ever had a rad cap top seal cause problems,allowing some minor coolant loss through the cap itself, even though the
conditions?
, and this time it's decided to pop a leak
Soooo,
