After much time/effort/money I have managed to sort out quite a few of the problems that my surf had when I bought it a few months ago, I have changed the radiator, changed the timing belt, fixed the exhaust, sorted the breaks, changed all the fluids and filters and fixed the broken anti roll bar bracket. She now runs like a dream. Damn rear window of death is still playing up (it seems like this is quite a common fault).
I have taken the thing to pieces and I think I may have identified the problem....
When you turn the key you can hear the motor running and it does open and close the window but you need to help it on its way, if you don't it just gets stuck and jerks up and down. On the metal assembly that opens and closes the window there is a coil of metal on the right hand side, this appears to be the cause of the sticking. I have used a whole tin of WD40 over the course of a couple of months and have hit it several times with a hammer, which seems to help a bit but not much.
Does anyone know how to fix this bit without having to fork out for a whole new assembly??
