Hi i've just bought my first Surf,(its fantastic) 1992 ssr-x 2.4td. When on motorways or uphill roads the power seems to totally dissappear. If i am travelling at about 80mph and approach a hill it slows down pretty fast. is this normal or is there a problem that needs addressing. Anyone have any ideas
Power loss going uphill
Yep, there is a problem, it's got the 2.4 engine fitted!Originally posted by AntshielHi i've just bought my first Surf,(its fantastic) 1992 ssr-x 2.4td. When on motorways or uphill roads the power seems to totally dissappear. If i am travelling at about 80mph and approach a hill it slows down pretty fast. is this normal or is there a problem that needs addressing. Anyone have any ideas
This doesn't do a thing. just been reading some other threads and looks like a possible torbo hose off somewhere, Thanx AnywayOriginally posted by paulhWith the 3ltr it only happens with the caravan on the back, usually cured by dropping it out of overdrive - give it a try.
But keep an eye on the temp gauge!!
http://www.apspropertyfix.co.uk/
No, 80mph is not normal!Originally posted by AntshielIf i am travelling at about 80mph and approach a hill it slows down pretty fast. is this normal
You've bought a 14year old two tonne truck, its not sports car.
Mine doesn't slow down when going up hill - it actually speeds up!
HeheAnother member of the 'A' team
Originally posted by AntshielThis doesn't do a thing. just been reading some other threads and looks like a possible torbo hose off somewhere, Thanx Anyway
In the green circle in the pic. check that it's on securely, in the yellow circle is the air temp sensor, check that it's there and not dangling down under the air filter housing. In the red circle is the turbo pressure sensor, check all the rubber pipes going to and from it are securely attatched.
I'll try it first thing Cheers....PS ive read many reports on the turbo light. some say it should come on and others say it should stay off "who's right"?(mine only comes on green with the ignition but goes off and stays off when started and driving)Originally posted by BUSHWHACKERIn the green circle in the pic. check that it's on securely, in the yellow circle is the air temp sensor, check that it's there and not dangling down under the air filter housing. In the red circle is the turbo pressure sensor, check all the rubber pipes going to and from it are securely attatched.
On aGen2 (which is what you've got) the turbo light should come on when the turbo is boosting, generally above 2200 rpm (ish).Originally posted by AntshielI'll try it first thing Cheers....PS ive read many reports on the turbo light. some say it should come on and others say it should stay off "who's right"?(mine only comes on green with the ignition but goes off and stays off when started and driving)
The Gen 3 light should be off, unless there is a problem..
Sounds like your little pipe has come off the turbo sensor..Last edited by dave.j.robbo; 9 November 2006, 23:51.It just does, OK?
Originally posted by dave.j.robboOn aGen2 (which is what you've got) the turbo light should come on when the turbo is boosting, generally above 2200 rpm (ish).
also, 3.0 2nd gen Surfs have no turbo light.
Ill try that too then cheers..Originally posted by dave.j.robboOn aGen2 (which is what you've got) the turbo light should come on when the turbo is boosting, generally above 2200 rpm (ish).
Sounds like your little pipe has come off the turbo sensor..Last edited by Antshiel; 10 November 2006, 12:09.http://www.apspropertyfix.co.uk/
My friend, you were absolutely right, the pipe was split at the end and i have just replaced it. Works a treat now, cant thank you enough. Cheers....Ps the little green light works tooOriginally posted by dave.j.robboOn aGen2 (which is what you've got) the turbo light should come on when the turbo is boosting, generally above 2200 rpm (ish).
