has anyone used the fans from the underslung air-con unit to replace the main rad-fan?
I have two redundant electric fans from when i removed the air con, and now a shot viscous coupling or clutch or somethin, so thoughts are coming into my head.
Would i need to seal over the old viscous coupling? and any ideas on wiring and mounting would be useful.
I was thinking of using a sheet steel template to move the shroud mountings to the right place for the new fans, could also bend over the top of the rad and put mountings through the front lip on the engine bay.
As far as the electrics go, i've got a reasonable knowledge of electrics however, i'm not sure about this one, i'm guessin i'm going to need to install one if not two thermostatic switches, to turn the fans on and off as required. Or is there another way?
Any thoughts?
Any thoughts?
