Hi Guys after spending hours reading posts etc and the write up on the removal of the head i just need some points clarified! Im replacing the head with a new fully built head which is to swap over with exisiting.
Iv started the removal process,
So far iv stripped alot of the required parts out of the way:
Ive basically: drained rad, removed fan shroud/viscous fan/hoses/electrical connectors/throttle body/cables/air cond pump/undone the injector metal feed pipes/undone what i could with inlet manifold/compelety undone turbo bolts/nuts.
What is left is: the exhaust manifold and on inlet side iv got the manifold with top bolts/nuts removed, cant get to the bottom ones and need to know do they need to be removed??
I havent yet removed : the rocker cover (but have unbolted it), timing cover, crank bolt thingy (how do i do this?), injectors, glows plugs. How many of these items actually need removing?
So i guess i just need some advise on what actually needed to be removed to now get to the head and get it whipped off!
Can anyone who has done this share their knowledge to get me sorted!??
Thanks in advance
Thanks in advance
