Hey been awhile since i've been on here,
Trying too flush the system from rust and then give it a good dose of antifreeze ready for the cold, thing is i've got the mechanical knowledge of a blind nat...so first port of call was to come here
Anyone got a guide too how to flush the engine (for idiots)
Thanks
Dude
Thanks
Dude
. I removed top hose and seperated heater hose from control valve on bulkhead. Make sure heater knob inside car is in hot position and attached hose pipe to heater valve (not too fierce a flow) randomly plug any two orfices untill clean water flows and continue with all of them the same way. I always leave heater pipe off when filling with water to allow any trapped air to exscape and only connect them when water appears at the filler on the thermost housing. This is a lot easier than taken off the bottom hose and if your not happy with the results drive around for a couple of days and do it again. Caution make sure the engine has cooled be for flushing though. This is my trusted method it also cleans out the cylinder block and heater. Oh forgot, I get my wife to put her hands over the orfices its easier and quicker and no you can't borrow her
. Good luck.
