Rev up / rev down
  • Rev up / rev down
    Greetings again
    When my 2.4 is at engine idle condition the tick over goes up then down and continues doing this any ideas. I do believe I have a turbo problem due to the check light coming on periodically but dont think this is linked coz it's only just started happening whereas the turbo problem needs a diagnostic check which I still aint sussed out how to do.
    Originally posted by gimpy
    Greetings again
    Here are some search titles for you to try......
    Throttle position sensor.
    Diagnostics.
    fault codes.
    You should find some answers under these.
      Thanks mate will try this diagnostic thingy, hoping by curing these problems i will improve all be it slightly my @17 MPG !!!!!
        Sounds like you've got worn/dirty fuel injectors, that would make the revs go up and down too.
        Try some Redex diesel injector cleaner in the fuel tank, get a 4.99 bottle, 500ml i think and pour it all into a quarter tank of diesel and give the truck a good blast up the motorway.
          I will try that , cheers, better take a second mortgage out though first !!!! motorways are long things and I love driving me truck
            alternatively, carefully remove the fuel filter... empty that into the tank.
            Fill the fuel filter with the redex... then give it a blast...
